Certificate Problem CTA 2.0.1
Hi all,
again there's a little problem with my CTA.
At the moment im testing the new version.
I'm using certificates for the machine and the user.
When i deploy only User certificate, the CTA is using the machine cert, not the user cert.
I checked twice, the user cert is installed in the personal store.
Any idea ?
Update: cta is now using the user certificate, but CS User Unknown in ACS, because it checks the Username, not the login ?!
regards
harry
1 REPLY
Re: Certificate Problem CTA 2.0.1
I think your issue has to do with the MAC address to Group settings. Try going to
'Network Access Profiles' -->
'Authentication' (for the profile) -->
'MAC Authentication Bypass Configuration' (even if you are not allowing Mac Bypass) -->
'MAC Authentication' -->
choose 'Default Group' for the "If a MAC Address is not defined or there is no matched mapping" section
230
