Change default timeout for VPN users for inactivity
I need to change the default timeout for VPN users connect through PIX 515 to automatically disconnect after 15 minutes of inactivity. I want to check
if this is the right command that needs to be added :
"timeout uauth 0:15:00 inactivity"
Appreciate with feedback. Thanks,
1 REPLY
Silver
Re: Change default timeout for VPN users for inactivity
timeout [uauth [hh:mm:ss] [absolute | inactivity]].Absolute and inactivity are abbreviated as follows
absolute: Run uauth timer continuously, but after timer elapses, wait to reprompt the user until the user starts a new connection, such as clicking a link in a web browser. The default uauth timer is absolute. To disable absolute, set the uauth timer to 0 (zero).
inactivity:Start uauth timer after a connection becomes idle
323
