Changed IP. PDM inaccessible.
I have a PIX 615 running 6.3. I have changed my IP addressing scheme and as a result, changed my private address on my PIX. I am now able to ping the new private address but I am unable to telnet or gain https access. I even tried a stealth port scan and all ports are reported closed.
Is there a way to recover?
1 ACCEPTED SOLUTION
Re: Changed IP. PDM inaccessible.
hi .. because you changed you IP scheme .. you also need to modify your ssh and http access before being able to connect to the PIX inside interface.
ssh inside
http inside
I hope it helps .. please rate it if ti does !!!
ssh inside
http inside
That was what I was looking for. I was able to poke around and find it when connecting via the console.
96
