Changing from Pix506E to 515E
I am upgrading our hardware from a PIX 506E to a 515E(6.3(5). I have a range of external IP addresses I use for services on the internal network. I had them working fine on the 506E. Once I moved to 515E I can not access anything from outside. I have had the ISP clear all ARP to make sure that would not cause a problem. I have looked over the configuration over and over with no success. I am sure the configuration is correct. Anyone have any advice or run into a similar problem?
ds
Bronze
Re: Changing from Pix506E to 515E
Can you connect from inside to outside? If you are unable to connect from outside to inside, check your access-list that is applied to the outside interface. Also you will need static translations to connect to inside resources from outside.
Yes, I can connect from inside to outside. I can change the accesslist and static translation to the outside interfaces' ip. And can connect great. But once I change the Static External IP back to what I need, it will stop connecting. Logs do not show a connection was ever attempted. Just for a better example I have posted the outside and statics that I have.
ip address outside xxx.xxx.xxx.2 255.255.255.192
ip address inside 10.xxx.xxx.2 255.255.255.0
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp xxx.xxx.xxx.3 37377 10.xxx.xxx.51 37377 netmask 255.255.255.255 0 0
static (inside,outside) tcp xxx.xxx.xxx.3 37363 10.xxx.xxx.52 37363 netmask 255.255.255.255 0 0
static (inside,outside) tcp xxx.xxx.xxx.3 6666 10.xxx.xxx.53 6666 netmask 255.255.255.255 0 0
static (inside,outside) xxx.xxx.xxx.4 10.xxx.xxx.54 netmask 255.255.255.255 0 0
static (inside,outside) xxx.xxx.xxx.5 10.xxx.xxx.72 netmask 255.255.255.255 0 0
static (inside,outside) xxx.xxx.xxx.6 10.xxx.xxx.71 netmask 255.255.255.255 0 0
static (inside,outside) xxx.xxx.xxx.7 10.xxx.xxx..71 netmask 255.255.255.255 0 0
ds
Hi Dustin,
Your config looks fine (port redirection, other static nat).
You mentioned you can connect from inside to outside, but not from outside to inside. Is is for a specific host or all of them?
Quick check - what's your route statement looks like? Do you have something like 'route outside 0.0.0.0 0.0.0.0 '?
Rgds,
AK
AK,
Thanks for your response. I have attached my full config. I do have my default gateway set.
: Saved
: Written by enable_15 at 14:31:28.795 UTC Wed May 24 2006
PIX Version 6.3(5)
interface ethernet0 100full
interface ethernet1 100full
interface ethernet2 auto shutdown
interface ethernet3 auto shutdown
interface ethernet4 auto shutdown
interface ethernet5 auto shutdown
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 intf2 security4
nameif ethernet3 intf3 security6
nameif ethernet4 intf4 security8
nameif ethernet5 intf5 security10
enable password **************** encrypted
passwd *************** encrypted
hostname chapix01
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-lsit 101 permit ip any any
access-list 101 permit icmp any any
access-list 101 permit tcp any host xxx.xxx.xxx.4 range 0 65535
access-list 101 permit udp any host xxx.xxx.xxx.4 range 0 65535
access-list 101 permit tcp any host xxx.xxx.xxx.5 eq www
access-list 101 permit tcp any host xxx.xxx.xxx.5 eq https
access-list 101 permit tcp any host xxx.xxx.xxx.6 eq www
access-list 101 permit tcp any host xxx.xxx.xxx.6 eq https
access-list 101 permit tcp any host xxx.xxx.xxx.7 eq www
access-list 101 permit tcp any host xxx.xxx.xxx.3 eq 37377
access-list 101 permit tcp any host xxx.xxx.xxx.3 eq 37363
access-list 101 permit tcp any host xxx.xxx.xxx.3 eq 6666
pager lines 48
logging on
icmp permit any outside
mtu outside 1500
mtu inside 1500
mtu outside2 1500
mtu intf3 1500
mtu intf4 1500
mtu intf5 1500
no ip address intf2
no ip address intf3
no ip address intf4
no ip address intf5
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
no failover ip address intf2
no failover ip address intf3
no failover ip address intf4
no failover ip address intf5
pdm history enable
arp timeout 14400
static (inside,outside) xxx.xxx.xxx.7 10.xxx.xxx.71 netmask 255.255.255.255 0 0
access-group 101 in interface outside
access-group 101 in interface inside
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.1 1
route inside 10.xxx.xxx.0 255.255.0.0 10.xxx.xxx.1 1
timeout xlate 1:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 10.xxx.xxx.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 5
terminal width 80
Thanks in advance for any suggestions!
ds
Hi Dustin,
Looking at your existing ACL, I think you don't need to use the same ACL you for both inside and outside interface. Outside ACL is meant to control incoming/inbound traffic into your network, while inside ACL is meant to control what traffic can go out from your internal/inside network.
The 1st statement 'permit ip any any' will overwrite other statement. It will permit access to your xx.3 - xx.7 hosts if the internet users know the public IP (can easily scan) without being restricted to use those specified ports.
For inside ACL, use different name/ID and specify permit ip any any and icmp any any for testing purposes, e.g:
access-list 100 permit ip any any
access-list 100 permit icmp any any
access-group 100 in interface inside
For the ACL 101, remove and paste the 1st permit ip any any statement so it will sit at the very end of the ACL. This will allow you to see the ACL statistics hitting your opened ports like 80 & 443 when you issue 'show access-list 101' command.
Then test access to, for example, accessing xx.xx.xx.5 via WWW & HTTPS from outside, as well as pinging its Public IP. Use the following commands to check the sessions:
sh access-list 101 -> look for any hitcount
sh conn | i 80 -> check incoming access to port 80 (www)
sh conn | i 443 -> check incoming access to port 443 (https)
If inbound access still failing, check the log for that server.
Other than that, looks ok.
Rgds,
AK
AK,
Thank you for the advice. As soon as I get back to my office I will give this a shot and let you know the outcome.
Dustin
125
