Changing IPs
We want to change all our IPs from 192.168.1.0/24 to 10.254.10.0/24. How do i do this without affecting users connecting through the pix(501). I intend to change the pix IP first.
This question might be outside this forum, but anyone know how to change all ip adresses of all computers in a domain without having to go to each individual system?
Re: Changing IPs
Hi .. you are probably using DHCP server. To check this out from any PC go to the command line and type in ipconfig /all search for a section
DHCP Server . . . . . . . . . . . : X.X.X.X
If you are using one then you will know which one that is. You can then modify the DHCP scope accordingly. If you are not using a DHCP server then you will have to visit every PC.
I hope it helps .. please rate it if it does !!!
Re: Changing IPs
Thanks man, but all are static IPs and not thru DHCP.
Daniel
102
