Changing SNMP
all,
we have set ro snmp community strings on our network devices and it was added to our nms. if we changed our ro snmp strings on the devices, will it stop sending traps to our nms and do we have to re-learn the device again?
1 ACCEPTED SOLUTION
Silver
Re: Changing SNMP
You may try using “snmp-server host” command. snmp-server host command specifies the recipient of all SNMP notifications and is used to configure the SNMP agent to send either traps or informs to multiple hosts. It is possible to use multiple instances of this command to specify more than one notification recipient.
Refer the below URL:
http://www.cisco.com/en/US/docs/ios/12_2/configfun/command/reference/frf014.html#wp1056809
1 REPLY
Silver
Re: Changing SNMP
178
