Checkpoint Secure remote over IOS firewall
Not sure this is the right place to post but I have a client whos having issues with Checkpoint secure remote over IOS based firewall. It does connect but seems to timeout. I'm using dynamic NAT so I dont this its a NAT timeout issue. Anyone got experience of this.
Interestingly I can run Netscreen VPN client (also IPSEC) without issue.
1 REPLY
Re: Checkpoint Secure remote over IOS firewall
I have found the following out about the FW1 client and you may be able to explain what the INSPECT IPSEC firewall rule on this Cisco is not functioning full and how I may resolve this as per original question:
What I have found regarding Checkpoint is that is uses :
Without NAT
IKE Protocol 500/UDP and 500/TCP
FW-1 topology - 264/TCP
Protocol ESP:50
Protocol FWZ:94
Over NAT
Encapsulated UDP - 2746
Both the Cisco and Netscreen use the following
Without NAT
IKE UDP/500
Protocol ESP:50
Over NAT
Encapsulated UDP 4500 (or 10000)
Could it be the ISPECT ISAKMP is not sufficient?
215
