Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
CheckPoint Secure Remote tunnel times out through 827 router
Help Please !
HQ : CP 4.1 SP4 Firewall
Remote Home VPN Users: Dialup or broadband connections
Remote Office: Secure Remote users behind a Cisco 827 dsl router (vs 12.2)
Problem: Remote home vpn users have no problem, but
Remote office users connect fine initially, but tunnel is dropped after twenty minutes. If the client is restarted, connection can be established with HQ. Also if you just continuously ping through the tunnel, all is fine. Please see config of 827 below.
version 12.1
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname lsb827ppp
logging buffered 4096 informational
logging rate-limit console 10 except errors
enable password 7 xxxxxx
ip subnet-zero
no ip source-route
no ip finger
ip name-server 66.109.x.x
ip dhcp pool main
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 66.109.x.x 66.109.x.x 66.109.x.x
ip dhcp-server 192.168.0.1
no ip dhcp-client network-discovery
interface Ethernet0
ip address 192.168.0.1 255.255.255.0
ip nat inside
no ip mroute-cache
interface Virtual-Template1
ip address negotiated
ip nat outside
ppp pap sent-username x.x.com password 7 xxxx
interface ATM0
no ip address
no atm ilmi-keepalive
bundle-enable
dsl operating-mode auto
interface ATM0.1 multipoint
pvc 0/35
encapsulation aal5mux ppp Virtual-Template1
ip classless
ip route 0.0.0.0 0.0.0.0 66.109.x.x
no ip http server
ip nat translation timeout 28800
ip nat translation udp-timeout 28800
ip nat translation finrst-timeout 28800
ip nat translation port-timeout udp 500 28800
ip nat translation port-timeout udp 2746 28800
ip nat pool natmain 66.109.x.x 66.109.x.x netmask 255.255.255.0
ip nat inside source list 1 pool natmain overload
access-list 1 permit 192.168.0.0 0.0.0.255
line con 0
password 7 xx
login
transport input none
stopbits 1
line vty 0 4
password 7 xx
login
scheduler max-task-time 5000
end
Thanks!!
Dave
1 REPLY
Bronze
Re: CheckPoint Secure Remote tunnel times out through 827 router
The tunnel going down is not exactly a problem if there is no traffic. When the SA lifetime expires, renegotiation of the new SA takes place if there is traffic to be tunneled across. In the absence of 'interesting' traffic the SA will not be renegotiated. This would also explain the pings keeping your tunnel up. Another possibility that you should look into is that of routing issues.
229
