checkpoint SecuRemote/SecuRClient passing traffic through PIX525
I'm in the process of configuring a PIX 525 to allow a checkpoint SecuRClient (inside) to initiate a vpn tunnel to a SecuRemote server (via Outside).
I have configured ACL's to allow UDP isakmp, esp and ah (both on the inside and the outside interfaces. Using the 'sh access-list' command after trying to initiate a vpn connect these ACL's are showing hits (htcnt=0).
All inside addresses will be PAT'd to a public address. Apart from ACL's to allow isakmp, esp and ah. Is there any other parameters I need to configure to allow this traffic through the PIX??.
thanks
Re: checkpoint SecuRemote/SecuRClient passing traffic through PI
do you have static nat to the computer in the inside interface, beside acl?
No there isn't a static map for this computer on the inside. If successfull, using checkpoint securclient software on the inside will be implemented to many may users, therefore using PAT for global translations is more cost effective.
114
