Community Member
Choosing the right hardware
I have a client with two small offices 40Km apart who wants them connected. I was looking at possibly having a 827 router at each end, Would I also need to purchase a VPN suite or can the routers do the job by themselves.
Does anyone have a better solution for what could be used.
1 REPLY
Community Member
Re: Choosing the right hardware
827 itself will have VPN function. Make sure you have at least 56 bit encryption IOS image load in the router.
Here is the sample config will fit your needs:
"Configuring a Cisco 827 for PPPoE with VPN IPSec NAT Overloading"
http://www.cisco.com/warp/customer/471/vpn_pppoe.html
Best Regards,
86
