Community Member
cisco 1700 clock problem
i have 2 1700 series cisco routers which i use in my home lab
both of which work perfectly except for one small problem
i have to keep resetting the clock after i have turned them off
i sure this means the the battery that keeps the clock settings
has gone flat,the problem is that i am unsure where the battery
is situated on the motherboard,the only contender is a little
silver cylinder with the markings s4 220 25v which sits in a
plastic socket just behind the on/off switch along side a marking
on the board of C717 and a + sign but there is nothing else marked
to say that this is a battery.
what i need to know is
what i described above actually the battery
and where can i get them?
regards
Melvyn Brown
ps 2 hours combing the net last night proved fruitless
1 REPLY
Re: cisco 1700 clock problem
HI Melvyn Brown, [Pls Rate if HELPS]
For any Purchase of Cisco Products please contact your nearby "Cisco Certified Partner / Vendor" in you Country for assistance.
Donot BUY cisco products accessories in local Market which will lead into some severe Hardware Issue in Future.
Purchase only the Branded Cisco Products for the same.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
119
