Cisco 2514 Router as a Firewall for Wireless
What would be the recommended IOS version and memory requirements to use a Cisco2514 router as a firewall. This is to be used to separate wireless access points from an inhouse wired network. There will be less than 5 wireless clients. Are there any sample config for this type of use.
Many Thanks,
Colin
Re: Cisco 2514 Router as a Firewall for Wireless
DOnt know whether i answered you earlier or not, But If you are looking for installing IOSFW (CBAC) on 2514, then it is not avialble for this platform.
Otherwise you have to simply rely on access-lists.
Nadeem
Get a PIX 506e, cheap and good wireless firewall. This is what I use for my wireless firewall (VPN). several vendors list them for slightly under 1K one vendor sells them for 960 with shipping included.
It will support 25 clients and 30mbit AES-128 traffic
using the PDM VPN wizard it would take you no longer than 10-15 minutes to have a working vpn wireless config.
116
