Cisco 3015 and intermittent error 734
To all:
I have a 3015 that is randomly/intermittently not allowing connections and users are seeing error 734 messages from their windows VPN clients. I have googled the message, and looked through Cisco documentation, and the 734 hints at bad user/pass pair. Same user/pass combo works 60% of the time.
The Cisco documentation also shows output of the log files on the box displaying failed authentication. my concentrator is not showing that.
Below is the information I'm seeing in the logs.
673 05/28/2007 22:41:52.560 SEV=4 PPTP/35 RPT=82 70.189.207.137
Session closed on tunnel 70.189.207.137 (peer 2749, local 1306, serial 41305), r
eason: User request (No additional info)
675 05/28/2007 22:41:53.550 SEV=4 PPTP/34 RPT=82 70.189.207.137
Tunnel to peer 70.189.207.137 closed, reason: None (No additional info)
676 05/28/2007 22:47:39.750 SEV=4 PPTP/47 RPT=83 70.189.207.137
Tunnel to peer 70.189.207.137 established
677 05/28/2007 22:47:39.800 SEV=4 PPTP/42 RPT=83 70.189.207.137
Session started on tunnel 70.189.207.137
678 05/28/2007 22:47:55.070 SEV=4 PPTP/35 RPT=83 70.189.207.137
Session closed on tunnel 70.189.207.137 (peer 1099, local 60299, serial 41397),
reason: User request (No additional info)
680 05/28/2007 22:47:55.070 SEV=4 PPTP/34 RPT=83 70.189.207.137
681 05/28/2007 22:48:13.700 SEV=4 PPTP/47 RPT=84 70.189.207.137
682 05/28/2007 22:48:13.760 SEV=4 PPTP/42 RPT=84 70.189.207.137
683 05/28/2007 22:48:29.040 SEV=4 PPTP/35 RPT=84 70.189.207.137
Session closed on tunnel 70.189.207.137 (peer 1100, local 24141, serial 41398),
685 05/28/2007 22:48:29.040 SEV=4 PPTP/34 RPT=84 70.189.207.137
686 05/28/2007 22:49:34.030 SEV=4 PPTP/47 RPT=85 70.189.207.137
687 05/28/2007 22:49:34.090 SEV=4 PPTP/42 RPT=85 70.189.207.137
688 05/28/2007 22:49:49.430 SEV=4 PPTP/35 RPT=85 70.189.207.137
Session closed on tunnel 70.189.207.137 (peer 1101, local 37115, serial 41399),
690 05/28/2007 22:49:49.430 SEV=4 PPTP/34 RPT=85 70.189.207.137
691 05/28/2007 22:50:49.420 SEV=4 PPTP/47 RPT=86 70.189.207.137
692 05/28/2007 22:50:49.480 SEV=4 PPTP/42 RPT=86 70.189.207.137
693 05/28/2007 22:51:04.860 SEV=4 PPTP/35 RPT=86 70.189.207.137
Session closed on tunnel 70.189.207.137 (peer 1102, local 48475, serial 41400),
695 05/28/2007 22:51:04.860 SEV=4 PPTP/34 RPT=86 70.189.207.137
696 05/28/2007 22:52:04.780 SEV=4 PPTP/47 RPT=87 70.189.207.137
697 05/28/2007 22:52:04.820 SEV=4 PPTP/42 RPT=87 70.189.207.137
698 05/28/2007 22:52:20.000 SEV=4 PPTP/35 RPT=87 70.189.207.137
Session closed on tunnel 70.189.207.137 (peer 1103, local 55612, serial 41401),
700 05/28/2007 22:52:20.990 SEV=4 PPTP/34 RPT=87 70.189.207.137
other information:
Software Rev: Cisco Systems, Inc./VPN 3000 Concentrator Version 4.7.Rel Mar 10 2005 12:35:39
Windows 2000 and XP clients using Windows VPN client. Most clients are on cable modems or cellular internet cards.
Any suggestions?
289
