Cisco 831 Router and Cisco VPN client not working
eleith
I've currently got a Cisco 1710 and a Cisco 831 router, with VPN functionality in it. I don't know a lot about VPNs but I have the 1710 up and running doing dial in users with the VPN client, and would like to get the 831 to do the same.
I've configured the 831 so it should work exactly like the 1710 based on http://www.cisco.com/warp/public/480/ipsec-ios-tacacs.html , but when the users connect, they login fine and get a secure connection, but then the router doesn't reply to any of the packets. The "Packets encrypted" entry goes up in the client as expected, but the "Packets descrypted" remains at 0. I've looked through the various documentation and debug logs and nothing seems amiss. The debug logs indicate the packets are being decryped, but they don't seem to be passed on to the destination IP on the LAN.
I've attached my config with the various ips+passwords removed, anyone got any ideas?
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname host1
enable secret 5 xxx
username user secret 5 xxx
aaa new-model
aaa authentication login userauthen local
aaa authentication login localauth local
aaa authorization network groupauthor local
aaa accounting delay-start
aaa session-id common
ip subnet-zero
no ip domain lookup
ip audit notify log
ip audit po max-events 100
crypto isakmp policy 3
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group groupname
key keyphrase
pool ippool
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set myset
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface Ethernet0
description Connected to Ethernetlan
ip address 1.2.3.4 255.255.0.0
interface Ethernet1
description connected to Internet
ip address 10.10.10.10 255.255.255.0
ip local pool ippool 1.2.3.5 1.2.3.10
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.10.20
no ip http server
ip pim bidir-enable
line con 0
exec-timeout 120 0
no modem enable
stopbits 1
line aux 0
stopbits 1
line vty 0 4
exec-timeout 120 0
scheduler max-task-time 5000
afakhan
Level 4
Level 4
Seems ok, make sure that your host inside can forward traffic for pool of IPs back to the router, also:
1 - no ACL blocking
2 - no NAT modifying traffic
Thx
Afaq
thanks for the reply, I've turned off all the NAT'ing and ACL's, still no luck, the strangest part I've noticed is that the router can't ping the assigned address of the client, which I would expect it to do.
I've set the router up as a Lan to lan connection for now, and I works fine, so I know the encryption and routing functionality is working ok.
Ewan
I have the same problem. I'm using VPN Client 3.6.4 on WinXP with IOS 12.2.(13)T3 (on a 7200 router). Everything connects and I see encrypted traffic going out, but there are no decrypted packets coming back.
If you get any fixes for this problem, please let me know.
-R
jagoe
You didn't post your ios version info, so I can't be sure the following is the solution to your problem. However, it might save you a lot of time if you read "ios bugs 12.2(13)T + 12.2(13)T1 break client-to-router vpn on 806" at http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&type=Subscriptions&CommCmd=MB?cmd=pass_through&location=outline@@.ee9360c/2
