02-24-2004 10:24 PM - edited 03-09-2019 06:32 AM
I am having some problems setting up an IPSEC VPN between a Cisco 837 ADSL Router and a Snapgear Pro ADSL router on another site.
Phase 1 Key exchange seems to happen OK, but then there seems to be a problem with the initiation of phase 2. Logs follow:
08:19:14: ISAKMP (0:255): sending packet to 20.20.20.20 my_port 500 peer_port 50
0 (R) MM_SA_SETUP
08:19:17: ISAKMP (0:255): SA is doing pre-shared key authentication using id typ
e ID_IPV4_ADDR
08:19:17: ISAKMP (255): ID payload
next-payload : 8
type : 1
addr : 30.30.30.30
protocol : 17
port : 0
length : 8
08:19:17: ISAKMP (255): Total payload length: 12
08:19:17: ISAKMP (0:255): sending packet to 20.20.20.20 my_port 500 peer_port 50
0 (R) MM_KEY_EXCH
08:19:17: ISAKMP (0:255): Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
08:19:17: ISAKMP (0:255): Old State = IKE_R_MM5 New State = IKE_P1_COMPLETE
08:19:17: ISAKMP (0:255): Input = IKE_MESG_INTERNAL, IKE_PHASE1_COMPLETE
08:19:17: ISAKMP (0:255): Old State = IKE_P1_COMPLETE New State = IKE_P1_COMPLE
TE
08:19:27: ISAKMP (0:255): received packet from 20.20.20.20 dport 500 sport 500 (
R) QM_IDLE
08:19:27: ISAKMP (0:255): phase 1 packet is a duplicate of a previous packet.
08:19:27: ISAKMP (0:255): retransmitting due to retransmit phase 1
08:19:27: ISAKMP (0:255): retransmitting phase 1 QM_IDLE ...
08:19:28: ISAKMP (0:255): retransmitting phase 1 QM_IDLE ...
08:19:28: ISAKMP (0:255): incrementing error counter on sa: retransmit phase 1
08:19:28: ISAKMP (0:255): no outgoing phase 1 packet to retransmit. QM_IDLE
08:19:47: ISAKMP (0:255): received packet from 20.20.20.20 dport 500 sport 500 (
R) QM_IDLE
08:19:47: ISAKMP (0:255): phase 1 packet is a duplicate of a previous packet.
08:19:47: ISAKMP (0:255): retransmitting due to retransmit phase 1
08:19:47: ISAKMP (0:255): retransmitting phase 1 QM_IDLE ...
08:19:48: ISAKMP (0:255): retransmitting phase 1 QM_IDLE ...
08:19:48: ISAKMP (0:255): incrementing error counter on sa: retransmit phase 1
08:19:48: ISAKMP (0:255): no outgoing phase 1 packet to retransmit. QM_IDLE
I have checked the Snapgear router and it is displaying the following message in the log:
Feb 25 06:21:32 Pluto[104]: "VPN-Connection" #50: max number of retransmissions (2) reached STATE_MAIN_I3. Possible authentication failure: no acceptable response to our first encrypted message
Feb 25 06:21:32 Pluto[104]: "VPN-Connection" #50: starting keying attempt 34 of an unlimited number
Feb 25 06:21:32 Pluto[104]: "VPN-Connection" #51: initiating Main Mode to replace #50
Feb 25 06:21:33 Pluto[104]: "VPN-Connection" #51: ignoring Vendor ID payload [Cisco-Unity]
Feb 25 06:21:33 Pluto[104]: "VPN-Connection" #51: received Vendor ID payload [Dead Peer Detection]
Feb 25 06:21:33 Pluto[104]: "VPN-Connection" #51: ignoring Vendor ID payload [ea35f8456a70f513...]
Feb 25 06:21:33 Pluto[104]: "VPN-Connection" #51: ignoring Vendor ID payload [XAUTH]
Feb 25 06:21:34 Pluto[104]: "VPN-Connection" #51: protocol/port in Phase 1 ID Payload must be 0/0 or 17/500 but are 17/0
Any ideas would be greatly appreciated.
Craig
03-01-2004 01:02 PM
Hi Craig,
Add a static route exclusively on concentrator and see if it works. If it works, the problem was most probably with the reachability only.
