I have configured my Cisco 877 for a VPN to a Cisco Concentrator, but the tunnel comes up, then goes down, then comes up then goes down etc. I just used a config from a Cisco 837. Below is the config and errors:
version 12.4
no service pad
hostname *
boot-start-marker
boot-end-marker
logging buffered 8192 warnings
enable password **
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.19.15.1 172.19.15.10
ip dhcp pool client
network 172.19.15.0 255.255.255.0
default-router 172.19.15.1
dns-server 192.168.21.1 192.168.21.2
lease 0 2
ip inspect name outbound tcp
ip inspect name outbound udp
ip inspect name outbound ftp
ip inspect name outbound http
ip inspect name outbound icmp
ip tftp source-interface Vlan1
username *** password 0 ***
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key #78697980c0n address 80.1.156.8
crypto ipsec transform-set vo_t_set esp-3des esp-md5-hmac
crypto map vo_t_set 10 ipsec-isakmp
set peer 80.1.156.8
set transform-set vo_t_set
match address 101
interface ATM0
no ip address
no ip unreachables
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 172.19.15.1 255.255.255.0
ip inspect outbound in
hold-queue 100 out
interface Dialer1
ip address negotiated
ip access-group inbound_acl in
no ip unreachables
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxx@hg57.xxxxx
ppp chap password 0 xxxxx
ppp pap sent-username xxxx@hg57.xxxxpassword 0 xxxx
crypto map vo_t_set
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip access-list extended inbound_acl
permit udp any any eq isakmp
permit esp any any
deny icmp any any timestamp-request
deny icmp any any timestamp-reply
permit icmp any any
permit udp any any eq ntp
permit tcp x.x.x.x 0.0.0.31 any eq telnet
permit tcp x.x.x.x 0.0.0.31 any eq 22
permit tcp x.x.x.x 0.0.0.31 any eq ftp-data
permit tcp x.x.x.x 0.0.0.31 any eq www
permit tcp x.x.x.x 0.0.0.31 any eq 443
permit ip 192.168.21.0 0.0.0.255 172.19.15.0 0.0.0.255
permit ip 192.168.30.0 0.0.0.255 172.19.15.0 0.0.0.255
access-list 50 permit 192.168.90.11
access-list 101 permit ip 172.19.15.0 0.0.0.255 any
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
access-class 50 in
exec-timeout 0 0
login local
length 0
scheduler max-task-time 5000
sntp server 158.43.128.33
end
When I connect my laptop to the Ethernet port and ping a remote server this is what happens, sometimes the tunnel comes up sometimes not:
*Mar 1 01:14:49.239: %LINK-3-UPDOWN: Interface ATM0, changed state to up
*Mar 1 01:14:50.239: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to up
*Mar 1 01:14:57.923: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
*Mar 1 01:14:57.927: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Mar 1 01:15:01.135: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
*Mar 1 01:15:18.075: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
*Mar 1 01:15:18.075: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
*Mar 1 01:15:19.075: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
*Mar 1 01:15:19.159: %LINK-3-UPDOWN: Interface ATM0, changed state to down
*Mar 1 01:15:20.159: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to down
