Cisco ACS 4.1.(1) Build 23
We are running Cisco ACS for Windows in our Company, and I was looking at Updates on Cisco Website, but the latest I found is for version 3.3, and from 2004.
Is it true that we don't have updates for this Software? or I'm looking in the wrong place?
Jorge
Re: Cisco ACS 4.1.(1) Build 23
The incremental updates between 4.1.1, 4.1.2, 4.1.3, are only available through TAC.
There are minor updates available for each 4.1.1, 4.1.2 & 4.1.3 available from CCO.
So if you're currently on the out-of-the-box 4.1(1) Build 23 with no patches applied, download the file named "Acs-4.1.1.23.5-SW.zip" follow the upgrade instructions, and then you'll be up to date within the 4.1(1) software train.
Richard.
So, the real latest version of Cisco ACS for Windows is which one?
If you go and buy ACS, you'll be given "4.1(1) Build 23", which you can then patch up to "4.1(1) Build 23 Patch 5" using the patches from CCO.
Anything higher and you need to acquire it from TAC somehow.
245
