Cisco ASA ASA5510-SEC-BUN-K9 2GE 3FE, 2GE not showing
mrbzumrbzu
we have bought the cisco part ASA5510-SEC-BUN-K9. According to the description, it has 2Ge and 3 FE ports but its showing me 5FE ports and doesn't have any GE port. How could i have 2 GE on this platform? is any special configuration/licence needs to be implemented.
Here is a show version
Result of the command: "sh ver"
Cisco Adaptive Security Appliance Software Version 8.0(4)
Device Manager Version 6.1(3)
Compiled on Thu 07-Aug-08 20:53 by builders
System image file is "disk0:/asa804-k8.bin"
Config file at boot was "startup-config"
Firewall up 331 days 20 hours
Hardware:   ASA5510, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
                             Boot microcode   :  CN1000-MC-BOOT-2.00
                             SSL/IKE microcode:  CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  :  CNlite-MC-IPSECm-MAIN-2.05
0: Ext: Ethernet0/0         : address is 001f.9f3c.71a8, irq 9
1: Ext: Ethernet0/1         : address is 001f.9f3c.71a9, irq 9
2: Ext: Ethernet0/2         : address is 001f.9fe3c.71aa, irq 9
3: Ext: Ethernet0/3         : address is 001f.9f3c.71ab, irq 9
4: Ext: Management0/0       : address is 001f.9f3c.71a7, irq 11
5: Int: Not used            : irq 11
6: Int: Not used            : irq 5
Licensed features for this platform:
Maximum Physical Interfaces  : Unlimited
Maximum VLANs                : 100
Inside Hosts                 : Unlimited
Failover                     : Active/Active
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
Security Contexts            : 2
GTP/GPRS                     : Disabled
VPN Peers                    : 250
WebVPN Peers                 : 2
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
Advanced Endpoint Assessment : Disabled
UC Proxy Sessions            : 2
This platform has an ASA 5510 Security Plus license.
Serial Number: **********
Running Activation Key: ******************************** Configuration register is 0x1
JORGE RODRIGUEZ
Level 10
Level 10
ethernet0/0  and ethernet0/1  are gig ready, if you go to interface mode on interfaces 0/0 and 0/1  you can specify speed
place a question mark
asa(config)interface ethernet0/0
asa(config-if)speed ?
you shoudl be able to see 10/100/1000 speed options
Rgds
Jorge Rodriguez
