Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Cisco ASA5500 WebVPN - Webfolders/WebDav not working Vista and IE 7
I currently have and ASA 5500 configured for webvpn for network Access using the portal webpage and CIFS configured bookmarks to point to network shares on the LAN. I can successfully connect, open and Save documents directly back into the cifs share using the Webfolders option (web folder icon) using IE7 and XP. however the webfolders option when using IE7 and Vista is not available. when I open a doc in from the portal in vista it will open in a local temp directory and I cannot save it directly back into the portal and CIFS file share.
Is this a know problem and is there a work around.
Eoin
375
