[cisco asa5510] routing between dmz and inside + vpn doesnt work
I have the following problem, i have a Cisco ASA 5510 and use 3 interfaces of it, (outside, inside and DMZ) on the inside i have serveral VLAN's
Now i have configured VPN and that works fine, so i started to configure the DMZ for the mailserver. i followd the cisco documentation for it http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806745b8.shtml
But when i have insert all the commands the VPN connection doesn't work anymore..
my configuration is as follow:
; ----------DMZ--------mailserver (192.168.2.2)
; internet--------------[asa 5510]---------inside/vlan600(192.168.6.0)
; --------VPN(192.168.45.0)
then i add the commands for the mailserver
[code]
access-list outside_int extended permit tcp any host 146.76.18.20 eq smtp
access-list dmz_int extended permit tcp host 192.168.2.2 any eq smtp
static (vlan600,dmz) 192.168.6.0 192.168.6.0 netmask 255.255.255.0
static (dmz,outside) 146.76.18.20 192.168.2.2 netmask 255.255.255.255
access-group outside_int in interface outside
access-group dmz_int in interface dmz
[code]
It goes wrong when i add the command:
and i have no idea why?
is there sombody who can help me?
regards,
Sebastiaan Moens
Re: [cisco asa5510] routing between dmz and inside + vpn doesnt
forgot to add my running config
I dont se why that last line would cause any problem but...I wonder.
You added an ACL to the outside interface. Does the ASA add hole for ipsec in a magical way. Pix OS doesnt. I would try permiting esp and isakmp. If it doesnt work, gatter some log by rasing the logging level to debug level.
369
