Cisco client fails to connect with 3030 using TCP/10000
Clients are connecting fine with UDP, but when I set a client to TCP/10000, the client fails to connect.
Here are the final messages gathered from the client log:
48 17:58:15.171 07/19/08 Sev=Info/4 CM/0x6310000E
Established Phase 1 SA. 1 Crypto Active IKE SA, 1 User Authenticated IKE SA in the system
49 17:58:15.187 07/19/08 Sev=Info/5 IKE/0x6300005E
Client sending a firewall request to concentrator
50 17:58:15.187 07/19/08 Sev=Info/5 IKE/0x6300005D
Firewall Policy: Product=Cisco Systems Integrated Client Firewall, Capability= (Centralized Protection Policy).
51 17:58:15.187 07/19/08 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to a.b.c.d
52 17:58:20.218 07/19/08 Sev=Info/4 IKE/0x63000021
Retransmitting last packet!
53 17:58:20.218 07/19/08 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(Retransmission) to a.b.c.d
54 17:58:25.218 07/19/08 Sev=Info/4 IKE/0x63000021
This looks like the client is asking for firewall settings and getting a CPP response from the 3030, but I have no idea why this would be happening - and as soon as it does, the 3030 no longer will acknowledge the traffic coming from the client.
The client does not have the CIC turned on, and the 3030 uses "Firewall Setting: NO Firewall" set on the group the client is connecting to, as well as the base group.
Any ideas or suggestions will be appreciated. Thanks in advance.
Per
1 REPLY
Re: Cisco client fails to connect with 3030 using TCP/10000
Per,
Do you have 3030 configured for Ipsec over tcp ?
Check under Configuration|System|Tunneling Protocols|IPSec|NAT Transparency
you should see a field to enable IPsec over TCP and specify the port.
Rgds
Jorge
157
