09-12-2007 08:17 AM - edited 02-21-2020 03:16 PM
I have cisco pix 515e with OS 7.2 on it
We have vpn client version 5 (the latest revision)
I have multiple subnets terminating a vpn off the pix and then on the
LAN behind the pix we have a router which is connected to another
couple of subnets via mpls
NOW when i vpn in with the client (after configuration) i can get to
the subnets with terminate a vpn off the pix but i cannot route to the
subnets via the router which connects to the mpls network!
I have tried adding in static routes and redistribute routes and a
couple of other things but any suggestions would be very helpful!
John
09-12-2007 08:37 AM
On the router you have to have a route for vpnclient's address.
On pix, please check split-tunneling.
You nerworks behind the router must be in this split-tunneling ACL.
09-12-2007 09:10 AM
have you got a link where i could read a technote or could you give brief description of how to config your suggestion properly, i have tried a couple of different ways and it aint successfull
Thanks in advance
John
