Community Member
Cisco Core Switch -Security-Help
Dear All,
I am still new to the world of Cisco.
I have here in My Network one Core Switch 4506 with 15 Edge Switch 3560.
We configure the Core Switch with This Command :-
A- )
HO-CSW-01(config)#username design privilege 15 password kabdesign
B- )
HO-CSW-01(config)#username support privilege 5 password support
C- )
HO-CSW-01(config-line)#login local
as you can see from the commands, i do not have CISCO Secure TACKCAS.
My manager asked me to find a way to create user name & Password for each one of my user so & to be able to Print a report who login & what time he enter.
I am searching for any Product - for example microsoft if i can enable RADUIS -
Can any one Please guide me if there is a way to configure the Core Switch with login to to the IP-Address of the RADUIS or any thing, please any one update me , will highly appritiated .
Re: Cisco Core Switch -Security-Help
To configure an FTP server record:
1. Log in to the switch
2. Access global configuration mode:
3. Use the ftp-record command to configure the default FTP server. The syntax is:
ftp-record ftp_record ip_or_host username ["password"|encrypted-password encrypted_pwd] {base_directory}
Yes, you can use microsoft radius (IAS) for your switches.Configure users on Windows and configure the switches as clients in IAS.
On the swithes you can use the following commands:
aaa new-model
aaa authentication login default group radius enable
radius-server host X.X.X.X
radius-server key cisco
