CISCO IDS-4235 pkgadd entercept.pkg problem on execution
I have a CISCO IDS-4235 (solaris 5.8) .
info :
I copy the /mnt/cdrom/products/agentsolaris to a local /etc/ciscohids
the files are admin , entercept.pkg , i execute the pkgadd like :
/usr/sbin/pkgadd -a /etc/ciscohids/admin -
d /etc/ciscohids/entercept.pkg
The following packages are available:
1 encpt Entercept agent
(sparc) 336
Select package(s) you wish to process (or 'all' to process
all packages). (default: all) [?,??,q]:
Processing package instance <encpt> from
</etc/ciscohids/entercept.pkg>
Entercept agent
(sparc) 336
Entercept
Please enter path for the Entercept agent directory: /etc/ciscoIDS
Please enter the IP address of the Entercept Console: x.x.x.x
Please wait for the testing of the host ...
Please enter the port number of Entercept server (default: 5000) :
Please specify the entercept agent type to be installed:
Solaris Server press 1
Solaris Web Server press 2
(default: 1) : 1
Please enter the agent name (default: myids):
Agent name is myids
The selected base directory </etc/ciscoIDS/entercept> must exist
before installation is attempted.
Do you want this directory created now [y,n,?,q] y
Using </etc/ciscoIDS/entercept> as the package base directory.
## Processing package information.
## Processing system information.
## Verifying disk space requirements.
## Checking for conflicts with packages already installed.
## Checking for setuid/setgid programs.
This package contains scripts which will be executed with super-user
permission during the process of installing this package.
Do you want to continue with the installation of <encpt> [y,n,?] y
Installing Entercept agent as <encpt>
## Installing part 1 of 1.
/etc/ciscoIDS/entercept/Params.db
/etc/ciscoIDS/entercept/ShieldGen.sun4u.SunOS.5.6
/etc/ciscoIDS/entercept/ShieldGen.sun4u.SunOS.5.7
/etc/ciscoIDS/entercept/ShieldGen.sun4u.SunOS.5.8
/etc/ciscoIDS/entercept/UnixAgent.rul
/etc/ciscoIDS/entercept/UnixAgent.scn
/etc/ciscoIDS/entercept/UnixApache.rmv
/etc/ciscoIDS/entercept/UnixApache.rul
/etc/ciscoIDS/entercept/UnixApache.scn
/etc/ciscoIDS/entercept/UnixApachehttp.rul
/etc/ciscoIDS/entercept/UnixIPlanet.rmv
/etc/ciscoIDS/entercept/UnixIPlanet.rul
/etc/ciscoIDS/entercept/UnixIPlanet.scn
/etc/ciscoIDS/entercept/UnixIPlanethttp.rul
/etc/ciscoIDS/entercept/agent.sun4u.SunOS.5.6
/etc/ciscoIDS/entercept/agent.sun4u.SunOS.5.7
/etc/ciscoIDS/entercept/agent.sun4u.SunOS.5.8
/etc/ciscoIDS/entercept/apacheEngine.so.sun4u.SunOS.5.6
/etc/ciscoIDS/entercept/apacheEngine.so.sun4u.SunOS.5.7
/etc/ciscoIDS/entercept/apacheEngine.so.sun4u.SunOS.5.8
/etc/ciscoIDS/entercept/configure.sun4u.SunOS.5.6
/etc/ciscoIDS/entercept/configure.sun4u.SunOS.5.7
/etc/ciscoIDS/entercept/configure.sun4u.SunOS.5.8
/etc/ciscoIDS/entercept/ePEngine.so.sun4u.SunOS.5.6
/etc/ciscoIDS/entercept/ePEngine.so.sun4u.SunOS.5.7
/etc/ciscoIDS/entercept/ePEngine.so.sun4u.SunOS.5.8
/etc/ciscoIDS/entercept/ePStub.so.sun4u.SunOS.5.6
/etc/ciscoIDS/entercept/ePStub.so.sun4u.SunOS.5.7
/etc/ciscoIDS/entercept/ePStub.so.sun4u.SunOS.5.8
/etc/ciscoIDS/entercept/encpt.conf
/etc/ciscoIDS/entercept/encpt.sun4u.SunOS.5.6
/etc/ciscoIDS/entercept/encpt.sun4u.SunOS.5.7
/etc/ciscoIDS/entercept/encpt.sun4u.SunOS.5.7_64
/etc/ciscoIDS/entercept/encpt.sun4u.SunOS.5.8
/etc/ciscoIDS/entercept/encpt.sun4u.SunOS.5.8_64
/etc/ciscoIDS/entercept/exceptions.db
/etc/ciscoIDS/entercept/general.rul
/etc/ciscoIDS/entercept/levels.db
/etc/ciscoIDS/entercept/libhlmed.so
/etc/ciscoIDS/entercept/mod_apacheStub.so.sun4u.SunOS.5.6
/etc/ciscoIDS/entercept/mod_apacheStub.so.sun4u.SunOS.5.7
/etc/ciscoIDS/entercept/mod_apacheStub.so.sun4u.SunOS.5.8
/etc/ciscoIDS/entercept/mod_cfginfo.so.sun4u.SunOS.5.6
/etc/ciscoIDS/entercept/mod_cfginfo.so.sun4u.SunOS.5.7
/etc/ciscoIDS/entercept/mod_cfginfo.so.sun4u.SunOS.5.8
/etc/ciscoIDS/entercept/newagent.scr
/etc/ciscoIDS/entercept/policies.db
/etc/ciscoIDS/entercept/sm
[ verifying class <none> ]
## Executing postinstall script.
It may take few minutes. Please wait ...
Install error, /etc/ciscoIDS/entercept/encpt.i86pc.SunOS.5.8 does not
exist.
pkgadd: ERROR: postinstall script did not complete successfully
Installation of <encpt> failed
Re: CISCO IDS-4235 pkgadd entercept.pkg problem on execution
The entercept package is for a host with a SPARC processor. The IDS Sensors use x86 processors.
Installing software that is not specifically released for the CIDS Sensors on a Sensor is not supported and can cause problems that would require you to re-image your Sensor . All supported CIDS software updates are posted on CCO at http://www.cisco.com/kobayashi/sw-center/ciscosecure/ids/crypto/
i make all the configuration in the sensor but i still not see the sensor in the HIDS. how i check if the sensor agent is up and running?
The Host Based IDS agent will not work on a Cisco Network IDS Sensor.
You can only insall the Network IDS updates on the Cisco Network IDS Sensor.
If your question does not pertain to running HIDS on a Cisco Network IDS (IDS-42xx appliance) then please repost your question as a new thread so as not confuse it with this message thread.
123
