cisco info center
I need to gather the following information from a PIX log.
•machine scanning—scanning a network to see the machines it contains
•port scanning—scanning the ports on a machine to see the running services
•port overuse—the abuse of a service offered by a particular machine
•too many accepts, rejects or drops— for instance, users receiving persistent denials of service
•oversized data transfers— for instance, excessively large FTP transfers
•too many Cisco PIX Firewall Info Mediator policy changes—could indicate suspicious activ
what do I need to set on the PIX to send this information to logging server.
Ive read that I can do this using cisco info center, but only with SUN?
can I do this using linux? is there a way to implement this on linux?
Please help.
Re: cisco info center
You can sent that information on all platform that are able to run a Syslog server.
Windows:
http://www.kiwisyslog.com/
http://support.3com.com/software/utilities_for_windows_32_bit.htm
Linux or Solaris:
Use Standard syslog that run on all distrubutions.
Documentation:
Accessing and Monitoring PIX Firewall:
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a0080172797.html
sincerely
Patrick
I actually was asking about a log analyzer, not a syslog server.
this CISCO software runs on a SUN machine and give the reports I would like to receive about port scans and DOS, etc.
Someone please help.
Try this one FWLOGSUM.
http://www.ginini.com/software/fwlogsum/
http://www.ginini.com/software/fwlogsum/converters/
It uses basicly PERL scripts and supports a wide range of Firewalls. You just need to install Perl in your Windows environment.
Commercial Windows version could be:
http://www.sawmill.net/
sincerely
Patrick
91
