Community Member
Cisco PIX 515 and VPN Capabilities Questions?
Hello. I have a cisco PIX 515 and was wondering if this firewall appliance is capable of doing VPN connection and acting as a endpoint. If someone can let me know, I would appreciate it. Thank you.
Re: Cisco PIX 515 and VPN Capabilities Questions?
Yes it is possible to use the PIX 515 as a VPN server for IPSec.
You can create:
- Remote VPNs - VPN client access
- Site 2 Site VPN
- Easy VPNs
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_data_sheet09186a0080091b15.html
sincerely
Patrick
Community Member
Thank for you the response. I know the 515E has VPN but I have the regular 515 and when I open up PDM, there is no option for VPN or IPSec. Maybe I am looking it incorrectly. Can you let me know if the regular 515 has VPN? does all PIX come with VPN installed or is it an option? once again thanks for your help.
If you a show version you will see if there is allready DES and 3DES encryption enabled.
If it is not then go the following link to get a free activation key. You need to enter your PIX serial number which you see also in the to get that key.
Activation key page:
http://www.cisco.com/en/US/partner/products/sw/secursw/ps2120/products_product_index09186a00801bc3ec.html
PIX OS Download page:
http://www.cisco.com/cgi-bin/tablebuild.pl/pix?sort=release
You might need to upgrade you PIX OS and PDM version to see that VPN features. What version are you running ?
example of VPN config with PDM:
http://www.cisco.com/en/US/partner/products/hw/vpndevc/ps2030/products_configuration_example09186a008055bd85.shtml
VPN wizzard in PDM:
http://www.cisco.com/en/US/partner/products/sw/netmgtsw/ps2032/products_installation_guide_chapter09186a008017a423.html
sincerely
Patrick
Community Member
hi patrick. i am trying eazy vpn with pix 7.0.4 ios with a 3640 router. the 3640 router is as a eazy vpn client . and the pix as the eazy vpn server. the client get connected and keeps on asking the xauth parameter. i read in the release notes that that eay vpn requires 12.2 and above secure ios for 806 routers. does the pix also support eaxy vpn client routers fo 800 series only. i did my config as oer the cisco configuration example.all my commands are right but it's still not working.help required urgent. if this true then pix sucks big time. they are forcing us to buy routers.they are becoming like microsoft. pls help
sebastan
Community Member
hellp patrick. I did a show ver on the console and this is what I got:
Cisco PIX Firewall Version 6.1(2)
Cisco PIX Device Manager Version 1.1(2)
Compiled on Mon 31-Dec-01 08:44 by morlee
fw-transw up 280 days 8 hours
Hardware: PIX-515, 64 MB RAM, CPU Pentium 200 MHz
Flash i28F640J5 @ 0x300, 16MB
BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: ethernet0: address is 0003.6bf6.f916, irq 11
1: ethernet1: address is 0003.6bf6.f917, irq 10
Licensed Features:
Failover: Enabled
VPN-DES: Enabled
VPN-3DES: Disabled
Maximum Interfaces: 6
Cut-through Proxy: Enabled
Guards: Enabled
Websense: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
ISAKMP peers: Unlimited
Serial Number: xxxxxxxx
Activation Key: xxxxxxxxxx xxxxxxxxxxxx xxxxxxxxxx
I tried to go to your first link and when I signed on, it just sent me to an "can't login page"
Do i just do the upgrade from the 2nd link?
100
