Cisco Prime Infrastructure 2.0 - built-in iptables/ip6tables
Please be carefull in dual-stack network environment. Default IPv6 netfilter is absolutelly unusable.
ade # ip6tables -L -n -v
Chain INPUT (policy ACCEPT 118K packets, 12M bytes)
 pkts bytes target     prot opt in     out     source               destination
    0     0 ACCEPT     tcp      *      *       ::/0                 ::/0               tcp dpt:21
    0     0 ACCEPT     udp      *      *       ::/0                 ::/0               udp dpt:69
    0     0 ACCEPT     tcp      *      *       ::/0                 ::/0               tcp dpt:80
    0     0 ACCEPT     tcp      *      *       ::/0                 ::/0               tcp dpt:443
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 4150 packets, 342K bytes)
IPv4 is more better :)
ade # iptables -L -n -v
Chain INPUT (policy DROP 0 packets, 0 bytes)
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpts:11011:11014
    0     0 DROP       icmp --  *      *       0.0.0.0/0            0.0.0.0/0           icmp type 13
    0     0 ACCEPT     all  --  lo     *       0.0.0.0/0            0.0.0.0/0
    0     0 ACCEPT     icmp --  *      *       0.0.0.0/0            0.0.0.0/0
    0    0 ACCEPT     all  --  eth0   *       0.0.0.0/0            0.0.0.0/0           state RELATED,ESTABLISHED
    0     0 ACCEPT     all  --  eth1   *       0.0.0.0/0            0.0.0.0/0           state RELATED,ESTABLISHED
    0     0 ACCEPT     udp  --  *      *       0.0.0.0/0            0.0.0.0/0           state ESTABLISHED
    0     0 ACCEPT     udp  --  eth0   *       0.0.0.0/0            0.0.0.0/0           udp dpt:161
    0     0 ACCEPT     udp  --  eth1   *       0.0.0.0/0            0.0.0.0/0           udp dpt:161
    0     0 ACCEPT     tcp  --  eth0   *       0.0.0.0/0            0.0.0.0/0           tcp dpt:22
    0     0 ACCEPT     tcp  --  eth1   *       0.0.0.0/0            0.0.0.0/0           tcp dpt:22
    0     0 ACCEPT     udp  --  *      *       0.0.0.0/0            0.0.0.0/0           udp dpt:162
    0     0 ACCEPT     udp  --  *      *       0.0.0.0/0            0.0.0.0/0           udp dpt:514
    0     0 ACCEPT     udp  --  *      *       0.0.0.0/0            0.0.0.0/0           udp dpt:1645
    0     0 ACCEPT     udp  --  *      *       0.0.0.0/0            0.0.0.0/0           udp dpt:1812
    0     0 ACCEPT     udp  --  *      *       0.0.0.0/0            0.0.0.0/0           udp dpt:1646
    0     0 ACCEPT     udp  --  *      *       0.0.0.0/0            0.0.0.0/0           udp dpt:1813
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:7
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:49
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:8082
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:8087
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10022
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10023
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10024
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10025
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10026
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10027
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10028
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10029
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10030
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10031
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10032
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10033
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10034
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10035
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10036
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10037
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10038
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10039
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10040
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:10041
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:16113
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:61617
    0     0 ACCEPT     tcp  --  *      *       x.x.x.x        0.0.0.0/0           tcp dpt:1522
    0     0 ACCEPT     udp  --  *      *       0.0.0.0/0            0.0.0.0/0           udp dpt:9991
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:21
    0     0 ACCEPT     udp  --  *      *       0.0.0.0/0            0.0.0.0/0           udp dpt:69
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0           tcp dpt:443
Chain FORWARD (policy DROP 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 16 packets, 1888 bytes)
    0     0 DROP       icmp --  *      *       0.0.0.0/0            0.0.0.0/0           icmp type 14
    0     0 ACCEPT     all  --  *      lo      0.0.0.0/0            0.0.0.0/0
ade #
  • Other Security Subjects
123
