11-06-2002 05:56 AM - edited 02-20-2020 09:19 PM
Could anyone give me a link to a full resource of CISCO protocol entries in RADIUS A/V pairs.
I know that shell: and ip: are such protocol entries but I would like to have a full description of all protocol entries.
any help would be greatly appreciated
11-06-2002 07:35 AM
You should be able to find your answer here:
11-06-2002 07:45 AM
I've read tham but the answer is not there
11-06-2002 08:01 AM
11-06-2002 08:10 AM
Also take a look at these RFCs 2865-2869
11-06-2002 11:10 PM
thank You very much...Ifound the answer there..but I have another question:
Could I make my NAS to ask the RADIUS server for authorization of every command performed by a user
11-06-2002 11:52 PM
I have the following configuration:hostname Reserve
logging rate-limit console 10 except errors
aaa new-model
aaa authentication login default group radius local
aaa authorization config-commands
aaa authorization exec default group radius none
aaa authorization commands 7 default group radius none
aaa authorization network default group radius
enable secret level 7 5 $1$Okb9$1B.pYCB3ccTOJXj9bchrD/
enable secret level 10 5 $1$WSXo$7OA2v/caiqJX.3CMijtcB0
enable secret 5 $1$nDrE$/CuSB04WniloBQ3h6a77J0
enable password 7 14141B180F0B
username cisco password 7 0822455D0A16
ip subnet-zero
no ip finger
no ip domain-lookup
interface FastEthernet0/0
ip address 172.16.3.15 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
ip classless
no ip http server
radius-server host 172.16.3.69 auth-port 1812 acct-port 1813
radius-server retransmit 3
radius-server key 7 104D000A0618
privilege configure level 7 terminal
privilege configure level 7 conf t
privilege exec level 7 configure
privilege exec level 7 configure terminal
line con 0
transport input none
line aux 0
line vty 0 4
exec-timeout 0 0
no scheduler allocate
end
One of my users is authorized by the radius server at priv-lvl=7, but when this user tries to run the command:conf t the following messages are logged:
tty67 AAA/AUTHOR/CMD (3442162769): Port='tty67' list='' service=CMD
1d23h: AAA/AUTHOR/CMD: tty67 (3442162769) user='lora1'
1d23h: tty67 AAA/AUTHOR/CMD (3442162769): send AV service=shell
1d23h: tty67 AAA/AUTHOR/CMD (3442162769): send AV cmd=configure
1d23h: tty67 AAA/AUTHOR/CMD (3442162769): send AV cmd-arg=terminal
1d23h: tty67 AAA/AUTHOR/CMD (3442162769): found list "default"
1d23h: tty67 AAA/AUTHOR/CMD (3442162769): Method=radius (radius)
1d23h: RADIUS: Command authorization not supported
1d23h: RADIUS: result does not match status after CMD
1d23h: AAA/AUTHOR (3442162769): Post authorization status = FAIL
Any help would be greatly appreciated
11-07-2002 07:12 AM
conf t is a priv-lvl 15 command by default.
You can change this in the IOS by using:
I don't recommend doing this though unless you have a few groups with different levels of access.
If this is the case, enforce authorization for priv-lvl 15 commands and assign it to the user profile.
Another thing you should consider is creating a local user with priv-lvl 15 in case your connection to the AAA Server goes down, so add local after radius:
aaa authorization exec default group radius local
aaa authorization commands 15 default group radius local
username admin privilege 15 password
11-07-2002 07:56 AM
Tnahk You very much for answering ..all I want is to authorize my commands, but it seems that RADIUS protocol does not support per-command authorization. So, I installed TACACS+ server.
I am not going to rate Your answer, because I've already got one like this
11-07-2002 08:01 AM
Good catch, it doesn't because RADIUS uses on access request packet which authentication and authorization are part of the same request.
You can use it for exec, not command authorization.
