CISCO Protocol entries in RADIUS A/V pairs
Could anyone give me a link to a full resource of CISCO protocol entries in RADIUS A/V pairs.
I know that shell: and ip: are such protocol entries but I would like to have a full description of all protocol entries.
any help would be greatly appreciated
Re: CISCO Protocol entries in RADIUS A/V pairs
I've read tham but the answer is not there
Also take a look at these RFCs 2865-2869
thank You very much...Ifound the answer there..but I have another question:
Could I make my NAS to ask the RADIUS server for authorization of every command performed by a user
I have the following configuration:hostname Reserve
logging rate-limit console 10 except errors
aaa new-model
aaa authentication login default group radius local
aaa authorization config-commands
aaa authorization exec default group radius none
aaa authorization commands 7 default group radius none
aaa authorization network default group radius
enable secret level 7 5 $1$Okb9$1B.pYCB3ccTOJXj9bchrD/
enable secret level 10 5 $1$WSXo$7OA2v/caiqJX.3CMijtcB0
enable secret 5 $1$nDrE$/CuSB04WniloBQ3h6a77J0
enable password 7 14141B180F0B
username cisco password 7 0822455D0A16
ip subnet-zero
no ip finger
no ip domain-lookup
interface FastEthernet0/0
ip address 172.16.3.15 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
ip classless
no ip http server
radius-server host 172.16.3.69 auth-port 1812 acct-port 1813
radius-server retransmit 3
radius-server key 7 104D000A0618
privilege configure level 7 terminal
privilege configure level 7 conf t
privilege exec level 7 configure
privilege exec level 7 configure terminal
line con 0
transport input none
line aux 0
line vty 0 4
exec-timeout 0 0
no scheduler allocate
end
One of my users is authorized by the radius server at priv-lvl=7, but when this user tries to run the command:conf t the following messages are logged:
tty67 AAA/AUTHOR/CMD (3442162769): Port='tty67' list='' service=CMD
1d23h: AAA/AUTHOR/CMD: tty67 (3442162769) user='lora1'
1d23h: tty67 AAA/AUTHOR/CMD (3442162769): send AV service=shell
1d23h: tty67 AAA/AUTHOR/CMD (3442162769): send AV cmd=configure
1d23h: tty67 AAA/AUTHOR/CMD (3442162769): send AV cmd-arg=terminal
1d23h: tty67 AAA/AUTHOR/CMD (3442162769): found list "default"
1d23h: tty67 AAA/AUTHOR/CMD (3442162769): Method=radius (radius)
1d23h: RADIUS: Command authorization not supported
1d23h: RADIUS: result does not match status after CMD
1d23h: AAA/AUTHOR (3442162769): Post authorization status = FAIL
Any help would be greatly appreciated
conf t is a priv-lvl 15 command by default.
You can change this in the IOS by using:
I don't recommend doing this though unless you have a few groups with different levels of access.
If this is the case, enforce authorization for priv-lvl 15 commands and assign it to the user profile.
Another thing you should consider is creating a local user with priv-lvl 15 in case your connection to the AAA Server goes down, so add local after radius:
aaa authorization exec default group radius local
aaa authorization commands 15 default group radius local
username admin privilege 15 password
Tnahk You very much for answering ..all I want is to authorize my commands, but it seems that RADIUS protocol does not support per-command authorization. So, I installed TACACS+ server.
I am not going to rate Your answer, because I've already got one like this
Good catch, it doesn't because RADIUS uses on access request packet which authentication and authorization are part of the same request.
You can use it for exec, not command authorization.
229
