Cisco routers and PIX firewall on ISDN connection
I have a Cisco 1721 with ISDN connection without fix IP address and sitting behind are PIX 515.
Can anyone show me how to configure the Cisco 1721 routers.
Do i need to set any routing pointing on the firewall or bla bla..
1 REPLY
Re: Cisco routers and PIX firewall on ISDN connection
This may not be the solution, but just a suggestion.
I suppose you want internet access via the ISDN. Since the PIX needs a default gateway for 0.0.0.0 traffic you should talk to your ISP and get some public IP adresses for your routers and PIX outside interface..... 2 IP addresses should be enough (255.255.255.252 subnet mask).
You can't set a default gw if you get a random IP address from a DHCP server each time the router dials.
Best regards
Jan Beining
91
