Community Member
Cisco Secure 4.0 syslog output?
Is it possible to produce a redirected syslog output of all events from a Cisco Secure 4.0 appliance? Obviously this capability exists from the various management platforms however can the underlying Linux O/S of an appliance be configured in this fashion?
Thanks in advance…
Bronze
Re: Cisco Secure 4.0 syslog output?
I think this feature is supported only from management platforms and not from the underlying O/S.
Community Member
You can do this with CSPM via using activestate perl, the net-syslog library and a simple perl script which gets the parameters from the alert and sends them as a syslog to whereever.
You can call the script under notifications
With IDS-MC you can use the perl that comes with it, the legacy perl script and do similiar.
Cisco Threat Response will send SNMP traps on alerts if configured.
I don't think the IDM does any of this but it does use Mysql so you might be able to do something there too.
103
