Cisco Security Agent - CSA Logging features
Please, I need yours help.
I have some questions which must be answered ASAP.
Is it possible
Logging - File copy from local drive to removable storages
Logging - File copy from network drive to removable disk
Logging – System parameters change
Logging – Connection to share on computer???
Everyone's tags (3)
3 ACCEPTED SOLUTIONS
Re: Cisco Security Agent - CSA Logging features
   -registry changes
Yes
  - changing or replacing important system  files
Yes
  or any system changes which maybe take to instability  operating system normal functionality..
Much harder, since this is a million different ways an o/s could become unstable, but looking at certain system registry keys and system/system32 directories will give you alot of information you are looking for.
Sorry it was incorrect.
Logging – Connection  to share folder on agent's computer?
Yes, you can log read/write access to a local folder which is shared, and with source @network in your rules, the actual attempt to connect to the share is probably a bit more difficult.
you could monitor connections on port 445 from @network, that would tell you if they're connected to a windows share, but not *which* windows share.
Actually you can monitor... if an event is logged into the Windows event logger, CSA can log that event as well....
We used the event logger to pull specific event log information into out CSA logs.. like, login and logout and disk errors.
I hope that helps,
-dt
Yes
Yes
Don't know what you are referring to...registry changes ?
What do you mean, just the actual attempt to connect to the machine, or the accessing of data on the share ?
Thank you for quick reply..
I am referring that
  -registry changes
   -registry changes
Yes
Yes
I hope that helps,
-dt
1328
