Cisco to 3015 Problem.
I have a 3015 configured for seventeen seperate L2L tunnels, one of the tunnels connects, then after 5m or so drops, then reconnects, then drops...etc. I am fairly certain the 3015 on my end is configured correctly, I don't have access to the Cisco router on the other side. I was able to get their admin to run debug for me though, I'll post it below. PLEASE help!
887: idbtype 0, encaps_size 84, header size 36, avail 84
886: 21:33:39: IPSEC(encapsulate): encaps area too small, moving to new buffer:
885: 21:33:39: IPSEC(encapsulate): error in encapsulation crypto_ip_encrypt
884: idbtype 0, encaps_size 84, header size 36, avail 84
883: 21:33:39: IPSEC(encapsulate): encaps area too small, moving to new buffer:
855: idbtype 0, encaps_size 84, header size 36, avail 84
854: 21:30:39: IPSEC(encapsulate): encaps area too small, moving to new buffer:
853: idbtype 0, encaps_size 84, header size 36, avail 84
852: 21:30:39: IPSEC(encapsulate): encaps area too small, moving to new buffer:
851: idbtype 0, encaps_size 84, header size 36, avail 84
850: 21:30:39: IPSEC(encapsulate): encaps area too small, moving to new buffer:
711: remote_proxy= 10.23.0.0/255.255.0.0/0/0 (type=4)
710: local_proxy= 10.2.136.0/255.255.248.0/0/0 (type=4),
709: (identity) local= 205.56.69.20, remote= 144.15.83.49,
708: sa_trans= esp-3des esp-md5-hmac , sa_conn_id= 2001,
707: sa_spi= 0x6888C602(1753794050),
706: (sa) sa_dest= 144.15.83.49, sa_prot= 50,
705: 21:27:49: IPSEC(add_sa): peer asks for new SAs -- expire current in 120 sec.,
704: sa_trans= esp-3des esp-md5-hmac , sa_conn_id= 2005
703: sa_spi= 0x651BB953(1696315731),
702: (sa) sa_dest= 144.15.83.49, sa_prot= 50,
701: 21:27:49: IPSEC(create_sa): sa created,
700: sa_trans= esp-3des esp-md5-hmac , sa_conn_id= 2004
699: sa_spi= 0x2CA6AD26(749120806),
698: (sa) sa_dest= 205.56.69.20, sa_prot= 50,
697: 21:27:49: IPSEC(create_sa): sa created,
696: spi= 0x651BB953(1696315731), conn_id= 2005, keysize= 0, flags= 0x4
695: lifedur= 28800s and 0kb,
694: protocol= ESP, transform= esp-3des esp-md5-hmac ,
693: dest_proxy= 10.23.0.0/255.255.0.0/0/0 (type=4),
692: src_proxy= 10.2.136.0/255.255.248.0/0/0 (type=4),
691: src= 205.56.69.20, dest= 144.15.83.49,
690: (key eng. msg.)
689: 21:27:49: IPSEC(initialize_sas): ,
688: spi= 0x2CA6AD26(749120806), conn_id= 2004, keysize= 0, flags= 0x4
687: lifedur= 28800s and 0kb,
686: protocol= ESP, transform= esp-3des esp-md5-hmac ,
685: src_proxy= 10.23.0.0/255.255.0.0/0/0 (type=4),
684: dest_proxy= 10.2.136.0/255.255.248.0/0/0 (type=4),
683: (key eng. msg.) dest= 205.56.69.20, src= 144.15.83.49,
682: 21:27:49: IPSEC(initialize_sas): ,
681: 21:27:49: IPSEC(key_engine): got a queue event...
680: 21:27:49: ISAKMP (0:40): deleting node 460806576 error FALSE reason "quick mode done (await()"
679: 21:27:49: lifetime of 28800 seconds
678: 21:27:49: has spi 1696315731 and conn_id 2005 and flags 4
677: 21:27:49: outbound SA from 205.56.69.20 to 144.15.83.49 (proxy 10.2.136.0 to 10.23.0.0 )
676: 21:27:49: lifetime of 28800 seconds
675: 21:27:49: has spi 0x2CA6AD26 and conn_id 2004 and flags 4
674: (proxy 10.23.0.0 to 10.2.136.0)
673: 21:27:49: inbound SA from 144.15.83.49 to 205.56.69.20
672: 21:27:49: ISAKMP (0:40): Creating IPSec SAs
671: 21:27:49: ISAKMP (0:40): received packet from 144.15.83.49 (R) QM_IDLE
670: 21:27:48: ISAKMP (0:40): sending packet to 144.15.83.49 (R) QM_IDLE
669: 21:27:48: ISAKMP: received ke message (2/1)
"668: from 144.15.83.49 to 205.56.69.20 for prot 3"
667: 21:27:48: IPSEC(spi_response): getting spi 749120806 for SA
666: 21:27:48: IPSEC(key_engine): got a queue event...
665: 21:27:48: ISAKMP (0:40): asking for 1 spis from ipsec
664: 21:27:48: ISAKMP (40): ID_IPV4_ADDR_SUBNET dst 10.2.136.0/255.255.248.0 prot 0 port 0
663: 21:27:48: ISAKMP (0:40): processing ID payload. message ID = 460806576
662: 21:27:48: ISAKMP (40): ID_IPV4_ADDR_SUBNET src 10.23.0.0/255.255.0.0 prot 0 port 0
661: 21:27:48: ISAKMP (0:40): processing ID payload. message ID = 460806576
660: 21:27:48: ISAKMP (0:40): processing NONCE payload. message ID = 460806576
659: spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x4
658: lifedur= 0s and 0kb,
657: protocol= ESP, transform= esp-3des esp-md5-hmac ,
656: src_proxy= 10.23.0.0/255.255.0.0/0/0 (type=4),
655: dest_proxy= 10.2.136.0/255.255.248.0/0/0 (type=4),
654: (key eng. msg.) dest= 205.56.69.20, src= 144.15.83.49,
653: 21:27:48: IPSEC(validate_proposal_request): proposal part #1,
652: 21:27:48: ISAKMP (0:40): atts are acceptable.
651: 21:27:48: ISAKMP: authenticator is HMAC-MD5
650: 21:27:48: ISAKMP: encaps is 1
649: 21:27:48: ISAKMP: SA life duration (basic) of 28800
648: 21:27:48: ISAKMP: SA life type in seconds
647: 21:27:48: ISAKMP: attributes in transform:
646: 21:27:48: ISAKMP: transform 1, ESP_3DES
645: 21:27:48: ISAKMP (0:40): Checking IPSec proposal 1
644: 21:27:48: ISAKMP (0:40): processing SA payload. message ID = 460806576
643: 21:27:48: ISAKMP (0:40): processing HASH payload. message ID = 460806576
642: 21:27:48: ISAKMP (0:40): received packet from 144.15.83.49 (R) QM_IDLE
641: 21:27:48: ISAKMP:received payload type 0
640: 21:27:48: ISAKMP (0:40): deleting node -395556257 error FALSE reason "informational (in) state 2"
639: 21:27:48: ISAKMP (0:40): incrementing error counter on sa: some bad notify
"638: spi 1753794050, message ID = -395556257, sa = 822444C0"
637: 21:27:48: ISAKMP (0:40): processing NOTIFY INVALID_SPI protocol 1
636: 21:27:48: ISAKMP (0:40): processing HASH payload. message ID = -395556257
635: 21:27:48: ISAKMP (0:40): received packet from 144.15.83.49 (R) QM_IDLE
634: 21:27:48: ISAKMP:received payload type 0
633: 21:27:48: ISAKMP (0:40): deleting node 766864525 error FALSE reason "informational (in) state 2"
632: 21:27:48: ISAKMP (0:40): incrementing error counter on sa: some bad notify
"631: spi 1753794050, message ID = 766864525, sa = 822444C0"
630: 21:27:48: ISAKMP (0:40): processing NOTIFY INVALID_SPI protocol 1
629: 21:27:48: ISAKMP (0:40): processing HASH payload. message ID = 766864525
628: 21:27:48: ISAKMP (0:40): received packet from 144.15.83.49 (R) QM_IDLE
627: 21:27:46: ISAKMP:received payload type 0
626: 21:27:46: ISAKMP (0:40): deleting node -2087709340 error FALSE reason "informational (in) state 2"
625: 21:27:46: ISAKMP (0:40): incrementing error counter on sa: some bad notify
"624: spi 1753794050, message ID = -2087709340, sa = 822444C0"
623: 21:27:46: ISAKMP (0:40): processing NOTIFY INVALID_SPI protocol 1
622: 21:27:46: ISAKMP (0:40): processing HASH payload. message ID = -2087709340
621: 21:27:46: ISAKMP (0:40): received packet from 144.15.83.49 (R) QM_IDLE
620: 21:27:45: ISAKMP:received payload type 0
619: 21:27:45: ISAKMP (0:40): deleting node -1979225688 error FALSE reason "informational (in) state 2"
618: 21:27:45: ISAKMP (0:40): incrementing error counter on sa: some bad notify
"617: spi 1753794050, message ID = -1979225688, sa = 822444C0"
616: 21:27:45: ISAKMP (0:40): processing NOTIFY INVALID_SPI protocol 1
615: 21:27:45: ISAKMP (0:40): processing HASH payload. message ID = -1979225688
614: 21:27:45: ISAKMP (0:40): received packet from 144.15.83.49 (R) QM_IDLE
613: 21:27:43: ISAKMP:received payload type 0
612: 21:27:43: ISAKMP (0:40): deleting node -957429003 error FALSE reason "informational (in) state 2"
611: 21:27:43: ISAKMP (0:40): incrementing error counter on sa: some bad notify
"610: spi 1753794050, message ID = -957429003, sa = 822444C0"
609: 21:27:43: ISAKMP (0:40): processing NOTIFY INVALID_SPI protocol 1
608: 21:27:43: ISAKMP (0:40): processing HASH payload. message ID = -957429003
607: 21:27:43: ISAKMP (0:40): received packet from 144.15.83.49 (R) QM_IDLE
606: 21:27:42: ISAKMP:received payload type 0
605: 21:27:42: ISAKMP (0:40): deleting node 1815547596 error FALSE reason "informational (in) state 2"
604: 21:27:42: ISAKMP (0:40): incrementing error counter on sa: some bad notify
"603: spi 1753794050, message ID = 1815547596, sa = 822444C0"
Re: Cisco to 3015 Problem.
This mostly could be a timer problem, not sure though
Not sure what you mean by timing. If you mean system time I have sync'd with an external NTP time server.
If you mean clocking I don't see any settings for specifying a clock source like you do in the router IOS for a WIC.
146
