Cisco VPN Client connection to remote lan ?
does anyone know if it is possible to connect from a PC via cisco vpn client to a pix 501 and then reach the remote lan the pix is connected to ?
To make it more clearly:
the pix 501 is connected via ipsec tunnel to a cisco vpn 3005 concentrator.
The pix also can handle a cisco vpn client connection from which I can reach the pc´s inside the lan.
Is it also possible to reach the remote lan ?
regards
Kai
Gold
Re: Cisco VPN Client connection to remote lan ?
in order to redirect the crypto traffic, pix v7 is required. unfortunately, pix 7 doesn't support 501.
So to be sure I am right:
With pix 501 it is only possible to work in the lan the pix is connected to ?
And when I want to work in the other lan the pix is connected to over ipsec I have to use a pix greater than 501 which can handle the PIX Version 7 is this right ?
Thanks a lot
Gold
according to the original post.
subnet a <--> pix a <--> www <--> remote vpn client
subnet a <--> pix a <--> www <--> pix b <--> subnet b
with pix a running v6.x, remote vpn client connected to pix a will not be able to access subnet b; even there is a lan-lan vpn between the pix a and pix b.
further, pix v7 supports 515/515E and above.
110
