Cisco VPN client port help?
jksnook
Is it possible to setup my VPN clients attaching to a 3005 to try multiple tcp/udp ports? The reason for this is some remote networks have filters built in that do not allow tcp/udp 10000 to leave thier network.
Jason
gfullage
Unfortunately no, it will only try the port number that is configured in the client (for TCP) or on the concentrator (for UDP). Sorry.
Most networks should allow UDP/4500 as that is now an IETF standard port for transmitting encrypted packets within UDP.
