09-13-2002 07:47 AM - edited 02-21-2020 12:03 PM
We are getting "peer not responding" error when trying to connect the VPN client to PIX. The PC with the VPN is on a wireless LAN and has internet access using ICS. (Note: VPN is on a different PC than the one that shares internet access.) The PIX is on a WAN and uses a Proxy server for internet access. We are able to ping and tracert from the VPN client PC to the PIX. Any ideas on what may be blocking the VPN when it tries to receive authentication?
Thanks you.
09-16-2002 04:53 AM
Is it a LinkSys wireless access point?
If so, there is a known issue with IPSEC VPN over the wireless. Are you using WEP encryption? Can you try with and then without the WEP? I think that trying to encrypt an already encrypted IPSEC stream over WEP starts getting ugly....
09-16-2002 06:26 AM
I am using a D-Link Router (DI-714) and WEP is turned off.
