Community Member
Cisco VPNClient's TCP port number
Our mobile users is at a client location and the VPN client work fine until the client put in a firewall and have many restriction on the Internet traffic. The network admin now want to know exact tcp port the CiscoVPN client use so he can allow it through his firewall.
My question is the VPN client said default is UDP and the TCP port if use need to match with the VPN server. Is it correct to say the VPN server will use the port 10000 as default port? and how do we config the server to use another TCP port number
BD
Bronze
Re: Cisco VPNClient's TCP port number
TCP port is configurable under ,configuration->tunneling protocol->Nat Transparency, and you can configure upto 10 ports for that(separated by commas).
10,000 is default.
Thx
Afaq
Community Member
Afaq,
Thanks for the info., I will try it with my PIX506E config and let you know the result.
BD
Community Member
Afaq,
Please help, could not find under, configuration->tunnel protocol->nat transpanrency?
Can you point to a sample config for this.
Bao
189
