Cisco web interface
I have a Cisco Pix 506 that is working fine with the exception of the web interface. I am more comfortable with it rather than telnet. I can telnet into it successfully but cannot access it through my browser. At the same time this happened, I also lost access to Terminal Services through my VPN (Port 3389). They may not be connected but was wondering what I can do to gain access again. The 506 Version is 6.1.
1 REPLY
Re: Cisco web interface
What message do you get in your browser when you try and go to the PIX? Are you definately using httpS://, not just http://? If you look at the config via your telnet session, do you see commands like:
http inside
If you do a "sho ver" from your telnet session, does the 2nd line show the PDM version you're running? Can you get to it from another PC? Are you sure you didn't upgrade your browser or Java version?
86
