09-29-2006 07:16 AM - edited 03-09-2019 04:21 PM
Has anyone gotten the cisco client vpn connection to worke with a Starband sattelite internet connection?
09-29-2006 11:29 AM
Kathy,
I have not personally used VPN Client over Satellite connection but one of the biggest challenges that VPN users face over Satellites, is the latency.
Are you using IPSec Over UDP or TCP. I have seen issues with satellite connections when using IPSec Over TCP. IPSec Over UDP should work fine.
I would test your VPN Client from a dial up to make sure that its working fine. Then try the satellite connection, if it does not work, Call the service provider and explain the situation and they should be able to provide you some additional guidance.
Also, logs from the Client and VPN Server should help you to isolate the problem of why you are not able to connect.
I hope it helps.
Arul
09-29-2006 01:18 PM
Thank you!
Here is my log. Using IPSec/UDP
Cisco Systems VPN Client Version 4.0.3 (C)
Copyright (C) 1998-2003 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600
15 10:51:26.296 09/26/06 Sev=Warning/2 IKE/0xA3000067
Received Unexpected InitialContact Notify (PLMgrNotify:841)
16 10:51:42.296 09/26/06 Sev=Warning/2 CVPND/0xE3400014
The VPN Client could not find the adapters GUID.
17 10:51:42.593 09/26/06 Sev=Warning/2 CVPND/0xE3400014
18 10:51:42.593 09/26/06 Sev=Warning/3 CVPND/0xE340000D
The Client was unable to enable the Virtual Adapter because it could not set the IP configuration into the registry.
19 10:51:42.593 09/26/06 Sev=Warning/2 CM/0xE310000A
The virtual adapter failed to enable
20 10:51:42.609 09/26/06 Sev=Warning/2 IKE/0xE3000099
Failed to active IPSec SA: Unable to enable Virtual Adapter (NavigatorQM:938)
21 10:51:42.609 09/26/06 Sev=Warning/2 IKE/0xE30000A5
Unexpected SW error occurred while processing Quick Mode negotiator:(Navigator:2199)
09-29-2006 01:48 PM
Kathy,
Based on the logs from the VPN Client, the issue does not seem to be with Satellite Connection. The VPN Client software itself is having problems finding the virutal adapter.
In your case, the best place to start is to uninstall the client manually and re-install the VPN Client. Please follow the below URL for details
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_tech_note09186a0080094b7f.shtml
BTW, did you have any other Cisco VPN Client installed prior to installing the current one.
Arul
09-29-2006 03:41 PM
Yes I did, in fact it worked before I did that but then my PC would not restart so then I did a restore but the VPN client did not fully restore so I had to reload it.
10-03-2006 07:48 AM
Kathy,
Looks like the VPN Client installation did not go smoothly and has something to do with the Virtual Adapter not getting installed properly.
At this point of time, I think your option is to manually uninstall the client and try to install it again.
Arul
10-04-2006 03:57 PM
I manually uninstalled cisco client and reinstalled now I get the following errors.
I have uninstalled and installed many times with same errors.
I don't even have to try and connect as long as the vpn client is open these errors keep coming.
1 16:56:11.593 10/04/06 Sev=Warning/2 CVPND/0xE3400003
Function CreateFile failed with an error code of 0x00000002(DRVIFACE:718)
2 16:56:12.140 10/04/06 Sev=Warning/2 CVPND/0xE3400003
3 16:56:13.765 10/04/06 Sev=Warning/2 CVPND/0xE3400003
10-24-2006 09:59 PM
Hi Kathy,
There are two grades of Satellite Internet service, consumer and commercial.
Consumer VSAT (StarBand/HughesNet/Wildblue) networks are shared services with greater contention factors. Yes, using UDP you will connect but the speeds will be close to dialup.
Commercial VSAT networks provide shared or dedicated services offering less contention. Using UDP you will connect but the speeds will rarely be as good as DSL/Cable or T-1.
VSAT Providers such as Spacenet and Unasat have products that will work in a VPN IP-SEC environment.
Hope this helps?
Steven Thompson
