CISCO2610 : IPsec transform-set, crypto-invalid input
bikashshrestha
while defining an IPsec transform-set on a cisco 2610 router i get the following errors:
Quote:
c2600(config)#crypto ipsec transform-set vpn-transform esp-des ah-md5-hmac
% Invalid input detected at '^' marker.
i am running a cisco 2600 series of following version:
Quote:
c2600#show version
IOS (tm) C2600 Software (C2600-IX-M), Version 12.3(15b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 25-Aug-05 13:38 by ssearch
Image text-base: 0x80008098, data-base: 0x80ECF9E0
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
c2600 uptime is 4 hours, 15 minutes
System returned to ROM by reload at 05:48:27 NST Mon Mar 1 1993
System image file is "flash:c2600-ix-mz.123-15b.bin"
cisco 2610 (MPC860) processor (revision 0x202) with 61440K/4096K bytes of memory.
Processor board ID JAD041108SN (2564682236)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
I am trying to setup a Remote Access VPN gateway using the reference from the following cisco documentation
http://www.cisco.com/univercd/cc/td/...m#xtocid200207
i am kinda clueless with this. i think the 2600 doesnot supports crypto command or has a different command to do the same job.
bikashshrestha
I have been googling like a mad man. I still don't have much clues since this is the first time i've ever touched a router but i think this cisco2600 thing needs an IOS upgrade. I think the IPSEC modules needed for the crypto is missing.
I checked this:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00801fc986.shtml#bckc2
and got that:
http://www.cisco.com/pcgi-bin/Software/Iosplanner/Planner-tool/iosplanner.cgi
means I have to find the man who gave me this router and get
either this:Valid Purchase or Sales Order Number and Customer Number
or this: PICA Registration Number and Verification Key
or this:CCIE Certification
whatever it is its a hell lot of work i assume. so before get going on this I need to be sure I am doing the right thing and If I do this correctly I will be getting a nice pat on my back from my boss. I am completely and insanely confused!
This c2600-ix-mz.123-15b.bin is not a crypto image.
Crypto enabled image will have a 'k9' notation somewhere in the image name.
Put the proper code image in the router to use crypto commands.
Vikas
