Community Member
CiscoSecureACS installation
We are attempting to install CiscoSecure 2.3(6) on Solaris 5.7 and 5.8 and receiving the following errors on the postinstall on both:
Loading properties from /opt/acs/config/CSConfig.ini
Finished loading properties.
Data Source = ORACLE
Driver Type = JDBC-Weblogic-Oracle URL = jdbc:weblogic:oracle:noc username = csecure password = ********
DBFactory Error: driver was unable to connect to the data source, driver msg: [ORA-12154: TNS:could not resolve service name - (csecure/********@noc)]
CSException: DBFactory Error: driver was unable to connect to the data source, driver msg: [ORA-12154: TNS:could not resolve service name - (csecure/********@noc)]
Failed.
CSdbTool failed. Results are in /tmp/cs_install.log file.
Results of this install are saved in the /tmp/cs_install.log file.
pkgadd: ERROR: postinstall script did not complete successfully
Installation of <CSCEacs> failed.
Any ideas???
Re: CiscoSecureACS installation
This points to an Oracle problem, namely that ACS can't connect to it.
Can you tnsping the database OK, and can you then use sqlplus and login using the exact same credentials you supplied during the ACS installation (username = csecure, db = noc and password = ).
Community Member
Follow the procedures here:
http://www.cisco.com/univercd/cc/td/doc/cisintwk/intsolns/secsols/aaasols/c262c3.htm#xtocid1
Make sure your Oracle dB instance has started. When you get it going, ensure you add the proper startup scripts in /etc/rc2.d.
Hope this helps.
Community Member
Thanks for the input but all of this is in place. I think the problem is that the postinstall script in trying to open a file named: /u00/oracle/product/8.1.7/orainst/unix.rgs but the "orainst" directory does not exist. The unix.rgs file is found within the /u00/oracle/product/8.1.7/install directory. Is there anyway we can point the postinstall script to the correct path?
Community Member
I withdraw the last entry made by me on Oct 15th. I found the problem and the post install executed flawlessly. I had put the wrong TSN name in during installation. Thanks for the help!
227
