Ciscoworks and SSH
we are using Ciscoworks. we want to enable SSH access on all Cisco Network devices. With the help of Ciscoworks Can i generate the report about the Device SSH compatibility? (Resource Manager Essentials 3.5)
Thank you
Vijay K
Bronze
Re: Ciscoworks and SSH
From my experience, I would say no. I am in the process of doing this for my company. We use Ciscoworks RME 2.6.
I created an inventory report with relevant information:
Hostname
Model
DRAM
FLASH
Current software version
Current software image
Those are the base items you will need. I exported that report to excel and then added my own fields:
Supports SSHv1
Supports SSHv2
SSH Image
SSH Image DRAM requirement
SSH Image FLASH requirement
Then used the IOS feature navigator to find an image that would support SSH.
Hi bretjaquish@hotmail.com,
Thanks for the reply. Me too already doing the same(IOS feature Navigator).
Plan to create a job and run the following command "Show IP SSH" to easy my work. Hope it will work. If you have any other easy way kindly tell me
Thank you
Vijay
130
