Community Member
CiscoWorks LMS Packet Capture - Automation
I've got CiscoWorks LMS2.5 (Dec2k5) up and running soundly and our security guys would like us to regularly audit the network traffic (sniff and review packets).
Is it possible to setup Ciscoworks to regularly run packet captures on devices?
Our network only has about 25 switches so we don't want to fork out for a full IDS.
Thanks in advance..
Bronze
Re: CiscoWorks LMS Packet Capture - Automation
Why don't you go for SPAN or RSPAN for packet monitoring?. This SPAN actually monitors the traffic. This enables one port to monitor the rest.
Hope this document will help you out in configuring SPAN and RSPAn.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12220se/3560scg/swspan.htm
Community Member
Thanks - yes I do already have a SPAN port setup - which is how we use the Packet Capture feature. I was hoping there might be a way of regularly running a capture.... If not i'll just end up writing a tcpdump script in php.
Thanks again.
362
