Class-map for CSC ignores
I have an application that is getting blocked by the Trend Micro CSC under the http class map. I need it to ignore http traffic from a 172.16.1.0/24, and allow all else. I haven't worked with class maps much, but my thinking is an ACL with the IP subnet, and a match statement under the class map, but where I have the question is, will the ACL be
permit ip 172.16.1.0 255.255.255.0 any
deny ip any any
or the other way around?
deny ip 172.16.1.0 255.255.255.0 any
permit ip any any
Re: Class-map for CSC ignores
with class-maps
permit ACL mean match
deny mean ignore
in ur case
deny traffic from the 172.16.1.0/24 to any
then permit any
good luck
and rate if helpful
OK I think I got it, havent applied it yet.
access-list CSC-Ignore extended deny tcp 172.16.1.0 255.255.255.0 192.168.0.0 255.255.248.0 eq www
access-list CSC-Ignore extended permit tcp any any eq www
class-map http
match access-list CSC-Ignore
thats right
but upong the ACL u have writen above u will ignore web traffic from 172.16.1.0/24 to 192.168.0.0
and will match any other web traffic
but nothing else
i mean no smtp,pop3 or ftp
if u want to match any thing else after the deny or ignore statement
u have to make permit ip any any
after u match it with class-map
apply it to a policy map
like polic-map global_policy (which is the default global policy)
class-map (ur calss-map name)
csc fail-open
then
service-policy global_policy global
in this case it will be applied to all interfaces
good luck
Rate if helpful
116
