clear xlate
For a couple of times we had to clear xlate for a particular machine on FWSM.
Background:
1.Server is able to ping till the interface ip of the FWSM.
2.Server is not able to connect on any port to ohter servers in other VLANS.
Appreciate your help on this.
Anonymous
N/A
Re: clear xlate
There are some NAT commands that are involved in an access-list change, like NAT0ACL and policy NAT. In these 2 cases, a change in the access-lists implicitly changes the rules of the NAT, and a 'clear xlate' is required. Refer usage guidelines of http://www.cisco.com/en/US/docs/security/fwsm/fwsm22/command/reference/c.html#wp1217767. Generally this can also happen when the ip addresses are not available for translation. If this is the case you can consider implementing PAT.
Re: clear xlate
clear xlate normally require when there is no further IPs are left for translation between private and public IP.you can reduce the refreash time . I guess bydefault it is 3 days.
246
