Client Problem using MAC OS
I was wondering if anyone has any suggestions. I am having trouble with a MAC connecting to a 3005. For Windows client everything works fines. I tried to use NAT-T just in case it was a problem. There are no firewalls on the client
Cisco Systems VPN Client Version 4.0.2 (C)
Copyright (C) 1998-2003 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Mac OS X
Running on: Darwin 6.8 Darwin Kernel Version 6.8: Wed Sep 10 15:20:55 PDT 2003; root:xnu/xnu-344.49.obj~2/RELEASE_PPC Power Macintosh
1 10:29:46.505 02/26/2004 Sev=Info/4 CM/0x43100002
Begin connection process
2 10:29:46.507 02/26/2004 Sev=Info/4 CM/0x43100004
Establish secure connection using Ethernet
3 10:29:46.507 02/26/2004 Sev=Info/4 CM/0x43100024
Attempt connection with server "65.126.58.132"
4 10:29:46.507 02/26/2004 Sev=Info/6 IKE/0x4300003B
Attempting to establish a connection with xxx.xxx.xxx.xxx.
5 10:29:46.635 02/26/2004 Sev=Info/4 IKE/0x43000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Nat-T), VID(Frag), VID(Unity)) to xxx.xxx.xxx.xxx
6 10:29:46.901 02/26/2004 Sev=Info/4 IPSEC/0x43700008
IPSec driver successfully started
7 10:29:46.902 02/26/2004 Sev=Info/4 IPSEC/0x43700014
Deleted all keys
8 10:29:51.662 02/26/2004 Sev=Info/4 IKE/0x43000021
Retransmitting last packet!
9 10:29:51.662 02/26/2004 Sev=Info/4 IKE/0x43000013
SENDING >>> ISAKMP OAK AG (Retransmission) to xxx.xxx.xxx.xxx
10 10:29:57.161 02/26/2004 Sev=Info/4 IKE/0x43000021
11 10:29:57.161 02/26/2004 Sev=Info/4 IKE/0x43000013
12 10:30:02.161 02/26/2004 Sev=Info/4 IKE/0x43000021
13 10:30:02.161 02/26/2004 Sev=Info/4 IKE/0x43000013
14 10:30:07.162 02/26/2004 Sev=Info/4 IKE/0x43000017
Marking IKE SA for deletion (I_Cookie=6146108614D01E08 R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
15 10:30:07.669 02/26/2004 Sev=Info/4 IKE/0x4300004A
Discarding IKE SA negotiation (I_Cookie=6146108614D01E08 R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
16 10:30:07.669 02/26/2004 Sev=Info/4 CM/0x43100014
Unable to establish Phase 1 SA with server "xxx.xxx.xxx.xxx" because of "DEL_REASON_PEER_NOT_RESPONDING"
17 10:30:07.669 02/26/2004 Sev=Info/5 CM/0x43100025
Initializing CVPNDrv
18 10:30:07.671 02/26/2004 Sev=Info/4 IKE/0x43000001
IKE received signal to terminate VPN connection
19 10:30:08.730 02/26/2004 Sev=Info/4 IPSEC/0x43700014
Deleted all keys
20 10:30:08.730 02/26/2004 Sev=Info/4 IPSEC/0x43700014
Deleted all keys
21 10:30:08.731 02/26/2004 Sev=Info/4 IPSEC/0x43700014
Deleted all keys
22 10:30:08.731 02/26/2004 Sev=Info/4 IPSEC/0x4370000A
IPSec driver successfully stopped
1 REPLY
Silver
Re: Client Problem using MAC OS
From what I can see, the message shown above means that client didnt' get any response on the UDP port. In case of NAT-T you would have to make sure that UDP 500 and UDP 4500 ports are allowed. You could also take a look at this document to check if you've missed some configuration step.
http://www.cisco.com/warp/public/471/vpn3k_MAC_os.html
96
