Client to spoke remote access vpn config problem
My name is Ram, i am configuring client to spoke remote access vpn configuration but I am able to connect to hub not to spoke. The network connectivity as follows.
HUB l2lVPN Spoke
client-->pixfirewall---------ASA5510----->local lan
ver 7.0.1 ver 7.0.4 12
Client can able to connect to the local LAN with the pool of 10.10.10.0 255.255.255.0. I did the configuration and i am facing a problem to connect to from home to the spoke side LAN. Nat and crypto configuration is done in US end also. I am attaching the configuration and please help me to resolve this issue.
Thanks in advance.
Ram
Re: Client to spoke remote access vpn config problem
You want to come in over a VPN client, then go back out the same interface on a L2L VPN?
This only becomes possible in v7.2, with the "same-security-traffic permit intra-interface" command.
Gold
Ram,
Take a look/read and verify with the following document:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805734ae.shtml
Hope this helps
238
