Client VPN Autoupdate Issue
I am trying to get the VPN client to auto update using a Concentrator 3005. I have a Windows 2k3 server running IIS 6.0. I have set the mime tags to application/octet-stream for the files. When I use the VPN the autoupdate log shows that it downloads the .exe and its in the folder. The logs have a few errors.
13:45:06 09/13/2006 : **Starting Autoupdate**
13:45:07 09/13/2006 : Downloading file http://www.server.com/updates/binary_config.ini
13:45:07 09/13/2006 : Autoupdate: downloaded in: 10
13:45:07 09/13/2006 : Downloading file http://www.server.com/updates/sig.dat
13:45:07 09/13/2006 : Autoupdate: downloaded in: 90
13:45:07 09/13/2006 : Autoupdate was unable to get file size out of http header
13:45:07 09/13/2006 : Autoupdate failed get filename from config
13:45:08 09/13/2006 : Downloading file http://www.server.com/updates/vpnclient-win-is-4.8.01.0300-k9.exe
What do these errors mean? I have got it to pop up and intiate the autoupdate but then it just locked up.
1 REPLY
Silver
Re: Client VPN Autoupdate Issue
To enable Client Update at the VPN group level, go to Configuration | User Management | Groups.
To add a new group especially for automatic updates, click Add and enter the name of the group. Then click Apply. The new group appears in the Current list. Now you can select the group and modify it for Client Update.
3 Next too modify a group in the Current list for Client Update, select the group and click Client Update. The manager displays the Client Update screen
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_administration_guide_chapter09186a00802d3abf.html#wp1177349
139
