09-13-2006 01:14 AM - edited 03-09-2019 04:10 PM
i cannot access https sites trough webvpn clienless (c2800nm-adventerprisek9-mz.124-9.T1.bin).
For example following:
url-text "example" url-value "https://meine.deutsche-bank.de"
not working.
See full debugoutput attached.
Is it BUG or i missing something? Do you have any tips on this?
Thnx in advance.
09-19-2006 05:35 AM
The issue may be due to Access lists configured to avoid navigating some cookies in the ACS server.
I think you have configured "filter url http 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 allow" which makes blocking of http pages.
03-11-2011 10:23 AM
did you get any solution to this?
i have c2800nm-advipservicesk9-mz.124-15.T10.bin and I get the same error SSL/TLS connection error when accessing any https sites.
SSL_connect:error in SSLv3 read server certificate B
1:error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
%SSLVPN-5-SSL_TLS_ERROR: vw_ctx: external vw_gw: webvpn i_vrf: 0 f_vrf: 0 status: SSL/TLS connection error with remote
