Clientless SSL VPN - works will local auth but not with RADIUS
I've configured Clientless SSL VPN but I can't get it to work with RADIUS authentication. Standard client VPN's and local ASDM access works OK with RADIUS. But when I connect through Clientless SSL VPN only my username with my local password works.
Has anyone any idea what the problem is?
Chris
ASA ver 8.0(3)
Bronze
Re: Clientless SSL VPN - works will local auth but not with RADI
Check if you have enabled RADIUS authentication on ASA while configuring the SSL vpn client.If not enable Radius authentication
You need to specify the authentication server group in the tunnel group for SSL.
Farrukh
I resolved the problem by configuring an Alias on each of the Connection Profiles and by ticking the box which says "allow user to select connection at login identified by alias from the table above".
Chris
186
